Podman/Container on AXC 2152
is there a way to run container on a axc 2152 with the latest firmware?
A couple of years ago i was able to run nodered as a container with balanea on the axc 2152. But since the latest firmware update i found no info about container on axc 2152
Can somebody help me here please?
Thanks & Regards
jochen
Firmware 2025.0 and later can manage OCI images using podman, without requiring root access.
Here’s a simple example:
(the OCI image in that example isn’t available for armv7 targets, but it demonstrates the concept).
There’s information on how to build a PLCnext Store app from an OCI image, here:
Basically, the container engine is already installed, so you can just power up the PLCnext Control device, start an ssh session as admin, and start typing podman commands.
Thanks.
So i can run podman on the cli and can pull each image which support arm. Does it need to match arm7 or just arm?
Correct.
I think arm should work. The AXC F 2152 a 32-bit armv7 device, so anything that works for a Raspberry Pi 3 should work. Not arm64.
