Problem entering docker container
Hi, I’m having some issues with docker and I was wondering if anyone had the same problem or could help. I installed BalenaEngine as explained on GitHub (https://github.com/PLCnext/Docker_GettingStarted/blob/master/getting-started/Part-01/README.md) I then pulled the postgres container but I can’t get inside the container. I got this error message: OCI runtime exec failed: exec failed: container_linux.go:296: starting container process caused “read init-p: connection reset by peer”: unknown As a comparison I did exactly the same steps on a RaspberryPI3 running a ARMV7 CPU, and it worked. I attached the respective console screenshots to this post. Regards Frédéric Blanchard We are using the latest 2020.0 LTS environment.
Moved into the Container section
The error seems to be a problem with the virtual console related to our system. We are working on it ! :slight_smile:
Hi, the problem has been identified and is expected to be fixed in FW2020.6 I will give an update on this again. G Jan
Hi, the problem is solved with FW2020.6. Here the new installer https://github.com/PLCnext/Docker_GettingStarted
