I am running into issues when trying to install the AXCF2152 2023 LTS SDK toolchain for the AXCF2152 with the 2022.6 PLCNext CLI toolchain. Here is the process that I am following on ubuntu 22.04 (inside a dev container → NB: this process worked in the past for earlier versions of the CLI toolchain and sdk’s)
1. Install "PLCnext_Toolchain_Linux_2022.6.sh" with the following process --> ./PLCnext_Toolchain_Linux_2022.6.sh --accept"
2. Install the 2023 LTS sdk for AXCF2152. Here is where it encounters problems. Namely :
" sudo plcncli install sdk -d /opt/plcnext_axcf2152_sdk -p pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2023.0.sh
[0%] Install SDK.
The format of the file ‘/workspaces/ppl/.devcontainer/plcnext/pxc-glibc-x86_64-axcf2152-image-sdk-cortexa9t2hf-neon-axcf2152-toolchain-2023.0.sh’ is not supported. Please proceed manually.
→ Did not find the expected usage information.
The expected information need to include the options ‘-y’ and ‘-d’.
The following usage information was given:"
When I run the above toolchain install bash file manually, I can see the -y and -d options (if I use the -h option).
Does anyone have any ideas where I am going wrong ? Or is there something that is wrong with the 2022.6 CLI toolchain ?
Cheers,
Lindsay
