Problems with PLCNEXT ENGINEER Version 2020.6.2
Working with PLCNEXT ENGINEER and had an unexpected shutdown, then I show the information that gives the program the error PLCnext Engineer, Version 2020.6.2 (Build 4.5.239.0) __ Unexpected Exception ====================================================================== Channel already closed. __ Exception chain: ---------------------------------------------------------------------- AdeFatalCommunicationException __ ====================================================================== __ Details ---------------------------------------------------------------------- __ AdeFatalCommunicationException ============================== Message: ------------------------------ Channel already closed. __ Stack trace: ------------------------------ __ Server stack trace: at c30.Invoke(IMethodCallMessage A_0) __ Exception rethrown at [0]: at c3e.Execute() at c6e.a(ICallStackFrame A_0) at c6j.get_IecInstancePath() at Ade.Internal.Plc.PlcCommunicationContextWrapper.a(ICallStackFrame A_0) at Ade.Internal.Plc.PlcCommunicationContextWrapper. <>c.a(ValueTuple2 A_0)_ _at System.Collections.Generic.List1.ForEach(Action`1 action) at Ade.Internal.Plc.PlcCommunicationContextWrapper.a(ICallStackInfo A_0, Boolean A_1) at Ade.Internal.Plc.PlcCommunicationContextWrapper.c() at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean & handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean & handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG & msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at Ade.Application.ApplicationStarter.Run() at (String[] ) at PCWorxNext.Startup.Main(String[] args) In addition to this, when I am connected to the PLC debugging, it systematically disconnects in a timely manner from the PLC (note, the connection between PC and PLC is direct via network cable). error 1 I also notice the following error when I connect to the PLC HMI error 2 Please, any way to improve PLCNEXT ENGINEER’s behavior?
Sorry for the delay. This exception will be fixed in the next release of PLCnext Engineer, version 2021.0. ~ Martin.
