Problems with SDK 2021.0 and eclipse
I have installed the SDK 2021.0 in eclipse. When I create a new project, I get 2 errors and 5 warnings that I cannot get rid of. After installing the SDK, even my old projects show these errors. Before the installation, everything worked fine. What can I do to fix this?
Hello Stefan, If this error occurs in an existing project, the cleanup and compilation project should help. However, you are giving me the information that the error occurs in a newly created project and in this case I have not been able to reproduce this behavior. My Configuration: Eclipse version Photon Release (4.8.0) plcncli version 2021.0 Eclipse add-in version 21.0.0.489 SDK for AXC F 2152 FW 2021.0 Best Regards Eduard
Hi Eduard, after I built my project several times, the error disapperared suddenly. I have no explanation for this at the moment. Best regards Stefan
