Hello, I’m trying to program a Temposonic Profinet Sensor in PLCnE 2019.9 but it is not possible to assign the Process data variables. I have tried it with the program variables as IN/OUT Port and also as Global variables but it does not work, Do you have any clue? Best regards. Angel.
Hello Angel, can you please expand the window showing “Standard Telegram 81 Output” so that it displays the Datatype as well?
Can you try attaching the Variable at the “AXC F2152 → PLCnext → Datalist” Column kind regards,
Oliver.
Hello Olver, as you know it is solved using USINT datatypes instead of word. TYPE
TEMPO_PN_IN: ARRAY[0..11] OF USINT;
TEMPO_PN_OUT: ARRAY[0..3] OF USINT;END_TYPE Best regards.
