Salutations!
After including AXL SE AI4 Modules to the Axioline F configurations and labelling functions (Analog Input 1, 2, etc), the input channels do get updated in the Process Data Item column for defining variables.
Additionally, under the Module Access tab for the defined Analog Input Modules I am unable to link to a PLC variable. As in, a new variable name is input into the Variable field for the input channel as so
and after hitting ‘ENTER’, the field is cleared. Works the same if the Variable is previously defined as a global or is completely new.
Aiming for re-install of PLCNE and re-testing.
Thank you,
