Proficloud Graph
Hi, I want to know if it is possible to make a graph like this in proficloud. It´s a grafana Graph.
Also if it is possible to add plugins of grafana to profiocloud?
Thanks, Lucas
Hi Lucas,
Thanks for your interest in Proficloud.io! Yes, this kind of graph can be easily used on Proficloud.io in the Time Series Data Service.
Currently it is not possible to add your own plugins as a user, do you have a specific plugin in mind?
You can see some of the visualization options of the Time Series Data Service here: https://proficloud.io/smart-services/time-series-data-service/And you can check out the FAQs for the Time Series Data Service here: https://proficloud.io/knowledge-hub/faqs/time-series-data/Did you know, that you can use Proficloud.io 's core Smart Services for free? With the Device Management Service you can keep an eye on all of your devices and with the free quota (20 metrics/variables) of the Time Series Data Service, it’s quite easy to get started.
Best regards from the Proficloud.io team!
