Profinet WBM Code 0x0020
Hi.,
I am trying to communicate AXC F 2152 with ILC131 through Profinet protocol, communication is establishing and data is also transferring.
But the Profinet status showing in WBM is Warning code 0x0020 and text message is Bit5: Neighborhood information is not available.
What does it mean?
How to clear this?
Hello, This discussion addresses that same issue: https://www.plcnext-community.net/en/discussions-2-offcanvas/pn-status-meaning.html I think this message will be cleared if you are using a Profinet switch, which supports LLDP and can return information about the network structure and participants. ~ Martin.
