Hello I am building a application switching a heater element. When the room temperature is to low i want to graduatly switch the heater element. I have a Phoenix Contact MCR-SL-UI-f: https://www.phoenixcontact.com/online/portal/gb The sensor gives a 0-10V signal. This i will use as input for the module. The lowest setting of the module is 61Hz. So if the temperature is to low → 0V the module starts pulsing PWM to the SSR. Lets say 1V = 6Hz This means the realay is switching at 160ms. Would this work for my heating element?
