Hello community engineers, I’m doing python with PLCnext, there is a tool called PyPLCnext like this, but the author writes very hard to understant, I do the first step as shown below, next step I copy the code then it doesn’t work, who has done python in PLCnext, please give me some experience, thanks
In case it helps:
There is an article on that topic here:
* https://www.plcnext-community.net/makersblog/read-and-write-plc-process-data-with-python/
* If you want to contact the author of that library, their email address on this page: https://pyplcnextrsc.readthedocs.io/en/latest/index.html
do i need to download putty , like the slide below it is putty logo
do i need to download puttyNo, any terminal emulator that can open an SSH session to a remote device will do.
e.g. a Windows command prompt will also work (using the command ssh admin@192.168.1.10 for example).
GitHub - AlexanderSkachkov/pyPLCn
I went through the example and ran it, it’s great, but I’m working on an image processing project
I will have my basler camera scan the object and give the coordinates, is there any way to send that coordinate data from python via PLCnext ? Thanks
