RE: Datalogger TSDB
Allright I have found it in the help system! When I use my eHMI, evertything works fine. As soon as I add the chart somewhere, the whole HMI page will turn black and all objects are invisible. Once I delete the chart and reload, everything works fine again.. Is this seen more often? Is this a bug or am I able to fix this? Arne
Hi Arne, I hope it’s OK that I’ve branched this into a separate ticket, since it is a different problem to the one described in the original question. We will check with the HMI guys and let you know. ~ Martin.
Hello Martin, do you allready have a solution for this? Arne
Hi Arne, no, sorry, I will send a reminder to the relevant support team. Martin.
Hello, I faced with similar issue several weeks ago. I solve the trouble with updating plcnext firmware from 2020.6 to 2021.0LST. The latest avaliable one. Best regards Oleksandr
