RE: Important Update Note 2021.0
Hello, Are these exceptions related? I just loaded 2021.0 last week. Thanks. 08.02.21 13:07:20.717 Arp.Services.Wcm.Internal.Config.HttpsCertificateConfig ERROR - Arp-Exception while loading config file! Message = Exception of type ‘Arp::System::Commons::Io::NotExistException’ was thrown
‘/opt/plcnext/config/Services/Wcm/HttpsCertificate.config’ does not exist.
at Arp::Services::Wcm::WebConfigurationManager::LoadConfig()
at Arp::Services::Wcm::WcmComponent::LoadConfig()
at Arp::System::Acf::Internal::Pm::ProcessManager::LoadComponentConfig(Arp::System::Acf::IComponent&) const
at Arp::System::Acf::Internal::Pm::ProcessManager::LoadComponentConfig(Arp::BasicString > const&) const
at Arp::System::Acf::Services::Internal::ProcessManagerServiceImpl::LoadComponentConfig(Arp::System::Rsc::Services::RscString<512> const&)
at Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentConfig(Arp::System::Acf::Internal::Sm::Data::ComponentExecutionData&)
at Arp::System::Acf::Internal::Sm::ComponentsController::SetupComponentsConfig()
at Arp::System::Acf::Internal::Sm::SystemManager::SetupSystem()
at Arp::System::Acf::Internal::ApplicationBase::SetupBasicComponents(Arp::System::Acf::Internal::ApplicationSetupKind, Arp::System::Acf::Internal::ProcessKind)
at Arp::System::Acf::Internal::ApplicationBase::Setup(Arp::System::Commons::Diagnostics::Logging::LogLevel, char const*)
at Arp::System::Acf::Internal::ApplicationBase::Main(int, char**, Arp::System::Commons::Diagnostics::Logging::LogLevel)
at Arp.System.Application(+0x2000c) [0x44100c]
at /lib/libc.so.6(__libc_start_main+0x97) [0xb66519a4] 08.02.21 13:07:18.335 Arp.System.Um.UserManager INFO - UM ldap configuration not found, disable ldap support completely
08.02.21 13:07:18.343 Arp.System.Acf.Internal.Sm.ComponentsController ERROR - Exception occurs while setting up config of component ‘Arp.System.Lm’: Exception of type ‘Arp::System::Commons::Io::NotExistException’ was thrown
‘/opt/plcnext/config/System/Lm/Lm.config’ does not exist.
Hi Alex, I have branched this out as a separate thread - sorry for the delay, I think your reply to the pinned post was not noticed before now. Those messages have been seen here before - they are not directly related to the issue described in the pinned post, as far as I know. This problem can also be solved by a Type 1 reset after the firmware upgrade. I will need to check if we have a root cause for these messages, and if there is a better solution than a Type 1 reset (which also deletes all user files on the PLC). ~ Martin.
