RE: Please give us feedback!
Had a couple items that I have ran into while programming for the first time.
                                             1. When you change a variable name in the variable list the associated code does not dynamically change, at least in ladder mode.
                                             2. When you copy ladder networks and paste them they do not paste with new network ID’s, and you have to edit each one to be unique manually.
                                             3. Change the ladder width to X amount of variables? Have to zoom out pretty far to see coil and beginning logic. Is this a setting? I could not find it.
Thanks.
Hello dpionk,
please see the answers from my colleagues in charge of your request:
1. You can choose the global search and replace attribute for variable changes ​ 2.With PnE 2021 it`s also possible to copy one network and it has another network ID ​ 3. In this case it has to be zoomed out further
Best Regards
Eduard
