RE: Python on the AXC 2152
/opt/bin/ipkg install python3 done /opt/bin/pip3 install --upgrade pip Requirement already up-to-date: pip in /opt/lib/python3.7/site-packages (10.0.0) Could not fetch URL https://pypi.python.org/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘pypi.python.org’, port=443): Max retries exceeded with url: /simple/pip/ (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))) - skipping Cant upgrade pip Please help. root@axcf2152:~# ipkg install openssl Package openssl (1.0.2n-1) installed in /opt/ is up to date.
Hi Azat, I’ve just googled it and found many hits, so this seems to be not unknown for PIP. Please check the issue on the GIT PIP project. cheers
