Hello, I am trying to read the Axioline Local Bus with PlcNext Engineer (Axioline F > Read AXL F Devices), but it shows me the “No Device Found” message. If I insert the AXL module manually, it works well. Then I conclude that it is not a hardware problem. I am using the PLCnextEngineer and FW 2019.9 version. I have had the same problem with 2019.3 version. Do you have any suggestion why the Read function is not working ? Regards, Sidnei
Hello Sidnei, As you have observed, this feature has never worked - from the “Features” page of the Community site: We also (unfortunately) currently have no information about which version this feature is planned for. Until then, I am afraid that manual I/O configuration is the simplest option for known, fixed I/O configurations. Martin.
Hello Martin, Sorry. I always check the Roadmaps but I haven´t observed this detail. Thank you for your help. Sidnei
No problem, it is not unreasonable to expect that a menu item that appears to do nothing, might not be working properly. Hopefully this will be fixed soon. Martin.
