Hello, is this configuration possible? See attached file. I think the AXC F 2152 is able to manage Profinet S2 REdundancy, but I’m not sure. The Switches connected to the AXCs should be able to manage 2 Profinet Application Relations. The lower Ring could be a MRP Ring. One of the switches would be MRP Master (MRM Lizenz) Thanks
Hi Angel, There is information on Profinet redundancy in the PLCnext Engineer help system - search for “redundant controller”. If this does not provide the answers, can you give more details on what is unclear? ~ Martin.
Hi Martin, the implicit question was if someone has tested the Profinet S2 Redundancy. Thanks
Hi Angel, I have passed this question to the relevant internal support team (reference no. 00132702). ~ Martin.
