Removing Metrics
If I have decide that I don’t want to log certain metrics anymore, is there any easy way to remove them from the checkbox selection screen? I know to uncheck and click “assign” so that they aren’t logging and counting against my metrics limit. But if I don’t want to use them again, is there a way to delete from the assign metric screen, or is the only solution to delete the item and then re-add it (after removing from the PLC program of course)?
Hi Ted, At the moment to completely remove the metrics, the device will have to be deleted, just like you described.
Thanks for the quick reply! have a great rest of the week!
