Using the WBM of an AXC F 3152, we try to import a backup of “Remaining Files”. The WBM then reports “Restore failed”:
Sadly it doesn’t tell us the exact cause of the problem. How can I find out what it is or fix the error?
Hello Armali,
I have the following two ideas:
-The firmware version does not match the backup
Can you check this again?
-Possibly there was some garbage in the overlay that is no longer accepted
This can happen if no reset type 1 is carried out before a firmware update.
Hallo, Tim,
thanks for your ideas, but …
Do you have another suggestion to back up or copy the content of the SD card? (Copying files on the - I think - ext4 filesystem is not trivial for users with just a Windows 11 PC at hand, is it?)
