I define the following struct in plcnext
MonElement : Struct
CurrentA : INT;
End_Struct;
StuctWithStruct:STRUCT
Repetition:UINT;
Valid:BOOL;
OneStruct:MonElement;
END_STRUCT;
With the following code, the 2 first element of the struct is correcty written. The struct element is not updated but the service don't issue any error (return code is DataAccessError::None
Arp::Plc::Gds::Services::WriteItem structItem;
structItem.PortName = "Arp.Plc.Eclr/SwS";
structItem.Value = RscVariant<512>::CreateStructVariant(3);
dataItems.WriteNext(structItem);
// Create an RscStructWriter for the struct
RscStructWriter<512> structWriter{ structItem.Value };
structWriter.WriteNextField((Arp::uint16)1);
structWriter.WriteNextField((Arp::boolean)true);
//ajout du tableau de structure de 20 element de 3 membres
RscVariant<512> OneStruct = RscVariant<512>::CreateStructVariant(1);
// Write the array item to the enumerator *before* creating the RscArrayWriter
structWriter.WriteNextField(OneStruct);
RscStructWriter<512> structWriter2{ OneStruct};
structWriter2.WriteNextField((Arp::uint16)2);
dataItems.EndWrite();
With a tab in a struct with the following declaration and code the error returned is typeMismatch,
Struct declaration in plc next:
TabUINT : Array [0..1] of UINT;
StuctWithTab:STRUCT
Repetition:UINT;
Valid:BOOL;
OneTab:TabUINT;
END_STRUCT;
structItem.PortName = "Arp.Plc.Eclr/SwT ";
//Add array of 2 uint16
RscVariant<512> OneTab = RscVariant<512>::CreateArrayVariant(2, RscType::Uint16);
structWriter.WriteNextField(OneTab);
RscArrayWriter ArrayWriter{ OneTab };
ArrayWriter.WriteNext((Arp::uint16)1);
ArrayWriter.WriteNext((Arp::uint16)2);
As their is no sample of writing Struct containing array or other struct is my code correct or is a problem somewhere?
Regards
Sorry for the delay.
Regarding the second issue - a structure containing an array - I can’t see what the problem is in your code.
This works for me (AXC F 2152 FW 2022.6, Toolchain version 2022.0, PLCnext Engineer version 2022.6):
**PLCnext Engineer types**
UINT_ARRAY_0_9 : ARRAY[0..9] OF UINT;
STRUCT_TYPE3 : STRUCT
MyBoolean : BOOL;
MyUInt16 : UINT;
MyFloat32 : REAL;
MyString : STRING;
MyArray : UINT_ARRAY_0_9;
END_STRUCT
PLCnext Engineer global variable declarationimage.pngC++ code
// Write the Struct port name and value
// Create the RscVariant representing the struct, with five fields
structItem.PortName = "Arp.Plc.Eclr/Globby3";
structItem.Value = RscVariant<512>::CreateStructVariant(5);
// Write the struct item to the enumerator *before* creating the RscStructWriter
// Fill the RSC Struct Variant with values
// The fields are written in the order that they are declared
structWriter.WriteNextField((Arp::uint16)42);
structWriter.WriteNextField((Arp::float32)42.31);
// Create an RscString variable to write to the next struct element
// IMPORTANT: The maximum size of the RscString MUST be the same as the maximum string size of the RscStructWriter object,
Arp::System::Rsc::Services::RscString<512> myString("String from C++");
structWriter.WriteNextField(myString);
// Create an RscVariant for the array field
RscVariant<512> arrayField = RscVariant<512>::CreateArrayVariant(10, RscType::Uint16);
// Write the field to the struct
structWriter.WriteNextField(arrayField);
// Get an array writer
RscArrayWriter arrayFieldWriter{ arrayField };
// Fill the RSC Array Variant with RscType::UInt16 values
arrayFieldWriter.WriteNext((Arp::uint16)42);
arrayFieldWriter.WriteNext((Arp::uint16)142);
arrayFieldWriter.WriteNext((Arp::uint16)242);
I will look into the other issue you mentioned.
Hi Martin , i tested your code and finally find the mistake on mine.
The trailing withespace on the portname is the cause of the problem but think the Error code returned by API must be Arp::Plc::Gds::Services::DataAccessError::NotExists and not Arp::Plc::Gds::Services::DataAccessError::TypeMismatch.
Just coming back to the first issue in your original question - a structure containing a structure.
I am afraid that once again I can’t see what the problem is in your code.
STRUCT_TYPE4 : STRUCT
MyInt16 : INT;
END_STRUCT
STRUCT_TYPE5 : STRUCT
MyBoolean : BOOL;
MyUInt16 : UINT;
MyFloat32 : REAL;
MyString : STRING;
MyStruct : STRUCT_TYPE4;
END_STRUCT
structItem.PortName = "Arp.Plc.Eclr/Globby5";
RscVariant<512> structField = RscVariant<512>::CreateStructVariant(1);
structWriter.WriteNextField(structField);
RscStructWriter<512> structFieldWriter{ structField };
// Fill the RSC Struct Variant with an RscType::Int16 value
structFieldWriter.WriteNextField((Arp::int16)42);
Martin thanks for you help, i don’t change my code but after trying yours mine is working without any code change.
