All that looks OK.<\/p>Are there any messages at all in the Output.log file related to DataAccess, during the startup of the PLCnext Runtime?<\/p>The DataAccess.acf.config file should include the DataAccessLibrary.acf.config file, which should instruct the PLCnext Runtime to create an instance of your ACF component. If there is a problem creating that component instance, then there should be an error message in the Output.log file.<\/p>
No, there are no logs related to DataAccess.
Isn't PLCnext Runtime automatically running when the equipment is turned on?
Is there anything I need to run separately?
[image.png](https:\\/\\/forum.plcnext-community.net\\/uploads\\/GQPYBUS1FODL\\/image.png)This image is /opt/plcnext/projects/Default/DataAccess.acf.config.
Even if you check with the export and echo commands, the $ARP_PROJECTS_DIR$ variable is not output.
Should I correct the $ARP_PROJECTS_DIR$ part?
Best regards.
