Hello, team!
Meet with some misunderstanding while work with grouped shapes on projects for PLCN Engineer 2025.0.3/2025.6.
According to help reference, to select separate item inside groped amount of objects, I have to use ALT button. But in case of ide 2025.0.3/2025.6 if I try to move groped object around hmi page, it seems that behavior of ide is similar to ALT pressed button, nevertheless it pressed or not. So it is impossible to move groped objects freely around hmi screen. I can move just some parts of group, on which mouse was pressed at the start of movement event.
Does some one faced with that issue also. Probably some new settings have to be modified?
BR
I have noticed the same; When moving a group, one has to be careful to not click on any sub-shapes as this will move only that one.
Actually, it is all about clicking on the group.
If you click once, it will select all objects, and if you click second time, it will select separate object inside the group. So, if I need to move groped elements, I have press and hold left mouse button over it, without release. And this group have not to be selected previously (no square hilite around it).
key functionality seems to be deprecated or lost.
