Good evening,
I have a servo motor which I have to rotate on different angles using Axl f pwm2 1H module. I need a function block to run this in plcnext engineer software to control the servo motor with the axl f pwm2 1H module
Good evening,</p>I have a servo motor which I have to rotate on different angles using Axl f pwm2 1H module. I need a function block to run this in plcnext engineer software to control the servo motor with the axl f pwm2 1H module</p>
Please give a solution asap
There is currently no PLCnext Engineer library available in the PLCnext Store for this function module.
For any questions about how this module works, please get in touch with the technical experts in your local Phoenix Contact office.
