Sharing PLCnext Loging API
Hi, This question is regarding the login API built in the PLCnext. We are planning on hosting a React App on the PLCnext.
This app needs to be secured by a login and I was wondering if it’s possible to use the same login API used by the phoenix HMI. If so the user could move between the Phoenix HMI and a React app without having to log in twice! The React app should remain independent. Thanks a lot
The documentation is here: https://www.plcnext.help/te/Service_Components/REST_data_interface/REST_data_interface_Authentication.htm
