I want to connect a simulated plant in simulink 2023a, and connect it with the PLCNext whith AXC F 2152 PLC, connecting the input and output of the plant to data in the plc, does anyone have documentation or tutorials on how to carry out this integration?
It sounds like you’re running the plant simulation on a Windows PC - is that correct?
Does the Simulink model make its “Process Data” (inputs and outputs) available through any standard communication interfaces, like OPC UA, Modbus/TCP, or Profinet?
