Hi all,
Currently i’m trying to get a VPN connection going with a:
AXC F2152 (HW: 04 FW: 2023.0.0 LTS)I’ve setup a proficloud connection, this is online and i’ve installed the ixon connecter which is also running and visable under PLCnext Apps:
IXagent plcnext 600021720000450.4.319.3.0 IXON B.V.Using following link to setup ixon : https://support.ixon.cloud/hc/en-us/articles/360015706099-PLCnext-IXagent
at step 9:
Start an SSH client (e.g. PuTTY) and connect to your PLCnext.Default username: admin. Default password: visible on the PLCnext’s housing.If you previously registered this device and it’s still listed in the IXON Cloud, make sure to first turn on Recover upon next registration before you continue.I run into a connection problem
admin@axcf2152:~$ ixagent-register.sh < COMPANY ID >Sending register command…nc: can’t connect to remote host (127.0.0.1): Connection refused
Is this something anyone else also ran into, the PLC is available in the proficloud and clearly has an out going internet connection. It is behind a firewall where i have no acces to, could ask ICT to open a specific port if i know which is causing the problem.
With kind regards,
Tim
SOLVED
I didn’t use Company ID but company name „IXON Product Tour“
Account menu.pngCompany ID „5377-8276-0741-9573-9501“
