Sources not on PLC
I have noticed that even when I use “Write an Start Project (with Sources)” there are no sources on the controller. In PCworx it was so, that when I ask to download the project with the sources, the sources have been on the controller. This would be needed as we have service personal that may not have the program with them and out of mobile cover to download the program from our server. Is there a other way to store the source code on the controller? You still need the user name and password to access the data. Peter Paul
Hello Paul, I can’t reproduce the described behavoir with 2029.9 Release (used controller AXCF 2152). Please check after project download, if the folder “/opt/plcnext/projects/PCWE/Src” is created and the PLCnEng project exists e.g. via WinSCP. If the failure persists, please give me more detailed information:
                                               1. Used PLC
                                               2. FW and PLCnEng Version/ Release stand.
Thanks & Best Regards Eduard
I have noticed that there has not been a file. just to make sure I have changed the SD card and now it looks like it is working.
