Spin button limit values
Dear community, I need to set a limited range for a spin button used in HMI, e.g. to use only values from 1 to 50. I have not found any setting for that in spin button properties. Could you give me any hints how it could be done. In program it is possible to check the variable but it I don’t like this solution. Thanks for any hints. Best regards Peter
Hi Peter,
In the current Version of PLCnext Engineer [2020.6.2] it is not yet possible to set maximum values on a spin button.
As you already mentioned, you will need to set those in your program for now. I do think that setting maximum values on the object itself would be very useful as well.
I passed your request to the development team but unfortunately cannot say when this will be implemented.
~ Martin. (ref: 201141)
