SQlite3Tool on AXC F 2152 with FW 2025.0.2 (25.0.2.92)
I am new to PLCnext and am having problems with SQlite3Tool.
I cannot get the test project to run with my current configuration
(AXC F2152 with FW 2025.0.2 (25.0.2.92)).
It works with older firmware. Does anyone have any experience with this?
Best regards, Michael
I assume you’re referring to this PLCnext Engineer library in the PLCnext Store:
Based on the release date of the most recent version of that library, it almost certainly needs to be updated to deal with changes in firmware version 2025.0, which are detailed here:
Application-relevant changes 2025 This documentation (also for download as a PDF file, b845ee9611647c5f87472624fa092fe3Hash value\n )\n specifies changes of the PLCnext Control firmware and SDK regarding the release 2025.0 that may be relevant to user-generated applications. You will need to ask the developers (using the Contact Developer button on the app page in the PLCnext Store) when they will be releasing a new version of that library.
