SSH or WBM won't work on Linux
Whenever I try to connect to the controller via SSH, it shows as if the password is wrong. This won’t happen when using windows (and using the same credentials).
The WBM won’t work as well in Firefox when using Linux; I’ve checked the firewall, but that does not seems to be the problem.
Thanks.
I’m not sure what you mean by this:
_Whenever I try to connect to the controller via SSH, it shows as if the password is wrong. This won 't happen when using windows (and using the same credentials)._Do you mean SSH on Linux?
Are you able to connect using SSH on Windows, from a Command Prompt? If so, then there is almost certainly a problem with the network configuration, not with the PLCnext Control device. That would also explain why WBM will not work on Linux.
Yes, I forgot to specify I’m trying SSH on Linux. Also yes, from Windows I have no problem whatsoever. I’m able to ping the PLC from Linux though; I’ll check again the network settings just to make sure.
OK. If you can login from Windows then there isn’t likely to be a problem with the PLCnext Control device - it looks like the ssh daemon and the web server are both running OK.
