SSL certificates when updating pip
Following the youtube video “How to upgrade Python and PIP package manager on PLCNext control …” I have incurred in the following issue that I couldn’t resolve with all the info I found online. Has anyone found a fix. It looks that the pip is not really working fine for anything, I have tried to use it for other update and I have got something similar root@axcf2152:~# pip3 install --upgrade pip
Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))’: /simple/pip/
Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))’: /simple/pip/
Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))’: /simple/pip/
Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))’: /simple/pip/
Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by ‘SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))’: /simple/pip/
Could not fetch URL https://pypi.python.org/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host=‘pypi.python.org’, port=443): Max retries exceeded with url: /simple/pip/ (Caused by SSLError(SSLCertVerificationError(1, ‘[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1051)’))) - skipping
Requirement already up-to-date: pip in /opt/lib/python3.7/site-packages (10.0.0)
I had the same problem once, it’s related to date and time on the plc different from the date and time of the server. Please just assign date and time from PLCNext engineering and should work.
Or in Linux with
date -s "12/31 23:59"
The problem occurs with new PLCs. When the date is set, it should be taken from the hardware clock. In the future, the machine will update the time after the hardware clock. The hardware clock can be checked with the tool
hwclock
It works. Thank You, Walter
