Target Simulink Matlab Box PC-EPC 1522
Is there a simulink target for the Box PC-EPC 1522?
Since the one that is downloaded is 1502 and it gives an error in the PLCnext engineer program
There is currently no SDK on our website for the EPC 1522, which is likely the cause of the problem you are seeing. As you mention, the SDK that appears to be for the EPC 1522 actually installs the SDK for the EPC 1502.
I have asked the product manager for a solution, and I will update this thread as soon as I have an answer.
There is currently no SDK on our website for the EPC 1522, which is likely the cause of the problem you are seeing. As you mention, the SDK that appears to be for the EPC 1522 actually installs the SDK for the EPC 1502.</p>I have asked the product manager for a solution, and I will update this thread as soon as I have an answer.</p>
Okay, because i need to run Simulink programs on the Box PC-EPC 1522 and the moment it won´t let me. Thanks.
Hello, do you know anything about running Simulink on the Box PC-EPC 1522
I’m really sorry but I have been unable to get any answers on this issue.
At the moment it appears that Simulink cannot be used with the EPC 1522, simply because the wrong SDK has been provided for this device. As soon as I have more information on this topic I will post it here.
The Phoenix Contact website has now been updated so the SDK for the EPC 1522 now contains … the SDK for the EPC 1522 (not the 1502).
Please download and install that SDK, and hopefully that will allow you to build a Simulink library that can be used with a PLCnext Engineer project for the EPC 1522.
Sorry for the delay.
Thank you very much for your work. Sorry for the inconvenience. All the best.
