The library does not support
Hi engineers! I want to ask how to fix the error " The library … does not support the controller ‘AXCF2152 v 2020.6.0’. The library supports AXC2152 v 2021.0.5"
Regards,
I’m guessing that your controller is running firmware version 2020.6.0.
You can check this in the top right corner of the web-based management (WBM) page:
[url="https://www.plcnext.help/te/WBM/WBM.htm"]https://www.plcnext.help/te/WBM/WBM.htm[/url]
If that's the case, you can remove this error by upgrading the firmware on the controller to version 2021.0.5 or later:
[url="https://www.plcnext.help/te/WBM/Administration_Firmware_Update.htm"]https://www.plcnext.help/te/WBM/Administration_Firmware_Update.htm[/url]
Hi Martin,
Thanks for your answer but unfortunately the error still appears. I have updated the firmware on the controller to version 2021.0.5 so I'm not sure if you can tell me what other possible optionls.
Regards.
![](https://scontent.fsgn2-1.fna.fbcdn.net/v/t1.15752-9/267565314_343322820955282_96551993558930966_n.png?_nc_cat=111&ccb=1-5&_nc_sid=ae9488&_nc_ohc=Z1pzi6iXk4AAX8OeMex&tn=ojaB90eFTPTl4OL3&_nc_ht=scontent.fsgn2-1.fna&oh=03_AVLh_-rP5LQp74_ZlvGeBLb3gJglgAXMdjj56Bd_iNMjOQ&oe=61E589A6)
It looks like you are using an old template for the controller in your project (2020.6). Please update the template of your controller to version 2021.0.5.
Hi Stefan,
I updated the template of my controller but it's does work :(
At what point are you getting this error -
- when you add the library to the project?
- when you build the project?
- when you send the project to the controller?
- some other time?
What library are you using?
