Timezone parameter
Hello, I have configured a NTP Server IP in the ntp parameter of PLCnext Enginner 2020.6 to adjust automatically of the PLCnext RTC. The time received is the UTC time. I have tried to adjust the time to my local time configuring the Time Zone parameter in PLCnext Enginner to -03:00, but the time not change. Is this parameter working in the 2020.6 version ? Thank you, Sidnei Marcondes
Hello, Could someone help me with this question? Thank you, Sidnei
Hi Sidnei, Sorry for the delay. This question is currently with the relevant support team. You can check the progress in our internal support system, with the reference number 00132979. ~ Martin.
Ok Martin, Thank you, Sidnei
Hi Sidnei, We finally have an answer to your original question, and that answer (in brief) is “no”. The Time Zone parameter in PLCnext Engineer that you mention currently has no effect on the clock or the time zone setting in the PLC. ~ Martin.
