My goal is to have an HMI button that when it is pressed, then I transfer a file from my plc (AXC F 2152) to a usb that is connected to my web panel (WP 6070-WVPS).
One way I was thinking is the same way I was downloading the file to my PC. This is through an HMI button. Of course this requires a script running on the web panel that says that any download should directly be saved to the USB connected on the panel. The problem with this is that when I press the HMI button from the web panel, then the panel performs a restart instead.
Another way I was thinking is through an HTTP post function but this requires several posts because my file data are approx. 10000 bytes and the library that I use requires strings of max 2048 bytes.
I test this behavior on WP-6185. And it download file to /home/plcnext/download folder.
But it also open blank screen.
I try to use “Open URL” and “Open support file” hmi functions. Both the same, file was downloaded to internal storage and blank page opened.
Try to upgrade firmware of WP to the latest one.
BR
I upgraded the panel firmware to the latest (4.3.4) and the same behaviour still happens unfortunately. Is there a way to factory default the panel in order to see whether this problem happened due to misconfiguration?
UPDATE: For some reason the firmware update was not completed. I reapplied the update and your solution worked! Thank you very much, I appreciate the response!
