Dear phoenix,
We need your help. We are in an escalation rewriting our PLC software to PLCnext engineer. We are at the stage where we are limited by adding new sources to our project. If we add one more source file then plcnext build will fail on linking, because we believe, the source list is too long.
If I move the folder containing our c++ project further up in the folder hierarchy (reducing the length of the path for each source file) we can compile and link our *.so file again.
So we are having a little ticking time bomb at the moment. At some point also with this workaround we'll exceed the limit, which will simply block us from adding new cpp files.
The error we get (is not very helpful):
[cmake]: [ 97%] Linking CXX shared library libYieldstarPlcNext.so
[cmake]: c:/localdata/sdks/3152.09/sysroots/x86_64-pokysdk-mingw32/usr/bin/x86_64-pxc-linux/../../libexec/x86_64-pxc-linux/gcc/x86_64-pxc-linux/9.3.0/real-ld.exe: CMakeFiles/YieldstarPlcNext.dir/intermediate/code/YieldstarPlcNextLibrary.cpp.o: in function `YieldstarPlcNext::YieldstarPlcNextLibrary::YieldstarPlcNextLibrary(Arp::AppDomain&)':
[cmake]: YieldstarPlcNextLibrary.cpp:(.text+0xe6): undefined reference to `Arp::System::Acf::LibraryBase::LibraryBase(Arp::AppDomain&, Arp::BasicVersion const&)'
[cmake]: c:/localdata/sdks/3152.09/sysroots/x86_64-pokysdk-mingw32/usr/bin/x86_64-pxc-linux/../../libexec/x86_64-pxc-linux/gcc/x86_64-pxc-linux/9.3.0/real-ld.exe: CMakeFiles/YieldstarPlcNext.dir/src/YieldstarPlcNextComponent.cpp.o: in function `YieldstarPlcNext::YieldstarPlcNextComponent::YieldstarPlcNextComponent(Arp::System::Acf::IApplication&, Arp::BasicString > const&)':
[cmake]: YieldstarPlcNextComponent.cpp:(.text+0x554): undefined reference to `Arp::System::Acf::ComponentBase::ComponentBase(Arp::System::Acf::IApplication&, Arp::System::Acf::ILibrary&, Arp::BasicString > const&, Arp::System::Acf::ComponentCategory, unsigned int, bool)'
[cmake]: c:/localdata/sdks/3152.09/sysroots/x86_64-pokysdk-mingw32/usr/bin/x86_64-pxc-linux/../../libexec/x86_64-pxc-linux/gcc/x86_64-pxc-linux/9.3.0/real-ld.exe: CMakeFiles/YieldstarPlcNext.dir/src/YieldstarPlcNextComponent.cpp.o:(.data.rel.ro._ZTVN16YieldstarPlcNext25YieldstarPlcNextComponentE[_ZT
