I have created a small script to help myself to easily build, deploy and start a runtime C++ application on the PLCNext (AXC F 2152). I have encountered a small problem while executing it. Namely, the PLCNext service seem not to start after invoking the command via a bash script:
ssh -tt plcnext ‘sudo /etc/init.d/plcnext start’
Surprisingly, I do receive the system output that the service has started successfully, but that does reflect the real situation because the D diode on the controller is still the only one that is blinking and the runtime/PLCNext project does not execute. If the service is started explicitly via an SSH session (without prior stop of it), the PLCNext service starts normally.
I wanted to check with you whether this is a expected behavior and the fault lies on my side, or whether it is simply a bug.
Kind regards,
Michael Czorniej
