We are reading 'REAL" values from a Modbus device and need to combine 2 array holding registers into one real value. What is the most efficient way to unpack/convert this. I need to do this multiple time to multiple devices so if there is a pre configured function block or should I do it by structured text.
Hi DustiSnorkel.
There was an earlier discussion on this topic, here:
Forum - PLCnext Community PLCnext Community Unfortunately links were broken and pictures were lost when this website was upgraded last year. I will try to retrieve the image in that thread, in case you can’t figure out the solution from the description.
