Upload project from ILC131
Hi everyone. Our company use ILC131 ETH PLCs. It’s included in ALARM MARINE SYSTEM in our fleet. Recently our servers crashed and some information like projects for PLCs lost. Is the way to upload project from our controllers? Thanks.
Hi Artem, that this forum focuses on the PLCnext Ecosystem, please address all other questions to your local subsidiary.
You can find your contacts via https://www.phoenixcontact.com/. For non PLCnext questions they’re normally able to help you much faster. However, I guess I can answer this one as well ?. The simple answer is, depends! If the project were deployed with sources it is possible to upload the transparent PC Worx project from the PLC.
- → Just check the ressource control dialog if the upload button is active. If the sources were not deployed you can not reassemble the PC Worx project, the only you can do is than to safe the bootproject. Hope that helped, Frank
Thank Frank for your fast reply. I wil try it! Best regards! Artem.
