Dear,
Recently I have started with developing C++ application for PLCNext control that makes use of user event tasks, while doing so I have raised some questions regarding the User Events.
1. Is it possible to receive events in the C++ code beside only triggering them? 2. When are you planning to implement the EVENT_TASK function block for the PLCNext? 3. Have you already created the example code for the GitHub repo? I have found a mention of it in an other [thread ](index.php?option=com_easydiscuss&view=post&id=1943&Itemid=221&lang=en)If so, where can I find it? 4. Is there any way to have the PLCNext task running constantly after receiving an User event? So far I have discovered that the task will perform a single cycle (in respect to the cycle time of the task setting the event) and then going back to idle again. Of course I can make use of the output ports that would signal the start of the task, but I would strongly prefer to apply User event tasks in my project.Looking forward to hearing from you!
Kind regards,
Michael Czorniej
