Using a PLCnext controller as a smart home device via Home Assistant
Hello, has someone more practise experiences or some manual, how to touch this task and lead it to real?
It this generally descripted under this link:
Using a PLCnext controller as a smart home device via Home Assistant - PLCnext Community This little demo project shows how to easily use a PLCnext controller as a smart home device in the open-source home automation software Home Assistant via the REST API and Modbus TCP. With the PLCnext controller you can use the Axioline components in your automation to add easily more powerful Outputs then the GPIO Pins of the Raspberry Pi, temperature sensors like Pt100 and bus systems like DALI. All you need is a working Home Assistant installationand a PLCnext controller with a small but runnable PLCnext project. Prerequisites Home Assistant Core 2021.1.5 Balena PLCnext Engineer 2020.6 AXC F […] Thank you. With best regards, Roman
