Using the different scan methods on VPN or USB to ethernet adapter
Hello there,
I am running into an issue where I am not able to scan for devices when I use a USB to ethernet converter, or connecting over a VPN. From what I have read this is probably because it does not support the broadcast message required for the profinet scan.
I can however ping and reach the device through these interfaces. I would like to use something like the ping scan, but this seems to fail with a popup stating ‘Could not communicate with the Profinet stack‘. I do not see an option to disable the profinet scan and I think this might be the reason that it does not get around to the ping scan.
Could someone confirm this suspicion or give me some lead on how I could find a way to solve this?
Something like a ping scan
Hello, I know about the ping scan. It however looks to me like it does not get to the ping scan, or other scan methods when I enable them if the profinet scan fails. I would like to know if anyone can confirm this suspicion, or if someone knows how to get the ping scan to work when the profinet scan does not work
When you use the “Online Devices/Controllers” editor it exclusively uses Profinet protocols (DCP) to assign IP/Subnet/stationame/Function/Location data.
The settings “Scan sources” (screenshot) apply to the “Physical Topology” edtior.
Does this answer your question?
Ahh thanks, things are starting to make a lot more sense. Unfortunately I do not have the physical topology tab available, do you know how I could access this?
And is it possible to assign the ip from this topology tab, or would I need to go to the WBM to set the IP in this case?
Know it makes more sense to me as well. I just checked and the Topology Editor is part of the license package I use.
Kinda weird that the settings are visible to you even though you don’t have a license for the feature (I assume).
Regarding your question about feature set of this “Physical Topology” editor, I suggest you take a look at the help.
Thanks for the help
