Warning occur when scan inovance Servo through Profinet in PLCnext Engineer
Hello Sir When I import the inovance Servo GSDML ,and scan it ,it show that warning as following picture: Revison doesn’t match . However, it can be import to TIA portal as normal. And I upload the GSDML document as attachment . Please check it. warning.png Thank you very much for your help!
Dear User, as you’ve mentioned is this just a warning, you can still import the device into your project. However, we’ve checked the GSDML and it includes the following key:
As the online device have obviously a newer FW version is the warning correct, but I agree it would be nice if the warning shows also the FW version in the GSDML. Hope that helps. Take care, Frank!
