I found theses executable in the PCWE directories: C:\\Program Files (x86)\\Phoenix Contact\\PC Worx Engineer 7.2\\EasySimSafety\\EasySim.exe C:\\Program Files (x86)\\Phoenix Contact\\PC Worx Engineer 7.2\\eCLRSim32\\EclrDeviceSimulatorLoader.exe C:\\Program Files (x86)\\Phoenix Contact\\PC Worx Engineer 7.2\\PlcNextSim\\PlcNextDeviceSimulatorLoader.exe Are theses tools used internally by PCWE or it is something intended to help us (so where is the doc) ?
Hi fblanchard, The EXE’s are dependencies of PWCE. The 1050 F target has simulation capabilities, so my guess is that those binaries provide simulation logic to some extend, but they could also have been implemented into dlls instead. I guess you only need to worry about the PCWE application and perhaps the activation wizzard’s in the start-menu. All other files (binary or not), will just complement the overall suite. If you are supposed to use them separately, documentation regarding will be provided at some point.
Hi fblanchard, as Vincent already suspected are those files internaly used for the IEC 61131-3 simulator who is available for the upcoming AXC F 1050. cu Frank
