Hello, I have a question, I need to know the minimum download and upload speed of the internet for proficloud to work correctly.
Hi, there is no minimum speed defined for the proficloud. In case of TSD it depends on the amount and type of values you want to transmit. If the connection is not very good, then the values are buffered internaly and send step by step. The result is that the values are visible with a delay in the cloud. It works also with mobile 2G, but a faster connetion would be reccomended.
Hi Arno, Thank you so much.
