How to reinstall all windows tools for C++ programming with Eclipse IDE (for 2019.0)? I had a problem with the eclipse and had to reinstall this software. After that I couldn’t use PLCnext toolchain.
So I decided to reinstall all the tools. I have done the following:
- uninstall eclipse (delete eclipse program and eclipse workspace folders)
- uninstall CLI (from control panel)
- delete SDK folder (C:\\SKDs\\AXCF2152\\2019.0)
- reinstall all that tools following to https://www.plcnext-community.net/index.php?option=com_content&view;=article&id;=335:install-windows-tools-for-c-programming-with-eclipse-ide&catid;=84&Itemid;=483⟨=en After that in the eclipse I’ve got double AXCF2152 target and following console info when creating new project:cmd.exe /c "“C:\\Program Files\\PHOENIX CONTACT\\PLCnCLI 2019.0 LTS/plcncli.exe” set target --add --version 19.0.0.17548 --name AXCF2152 --path "C:\\Users\\plsk31\\eclipse-workspace\\Td2019""cmd.exe /c "“C:\\Program Files\\PHOENIX CONTACT\\PLCnCLI 2019.0 LTS/plcncli.exe” set target --add --version 19.0.0.17548 --name AXCF2152 --path "C:\\Users\\plsk31\\eclipse-workspace\\Td2019""The target AXCF2152 19.0.0.17548 is ambiguous. Make clear which target you mean by specifying the version. Possible targets are:
- AXCF2152 19.0.0.17548
- AXCF2152 19.0.0.17548And eclipse autocompiler shows a lot of bugs in plcnext templates (Problem description: Symbol ‘Arp’ could not be resolved)
How to fix it and reinstall all the tools properly?
