.X vs .%X
I am a new PLCnext user. I am doing some bit level addressing, and wondering what the difference is between .X and .%X ? I am using .X and my code works the way I want, but was wondering what the difference is?? I looked through the Help and the PLCnext Info Center, but couldn’t find an explanation.
Thank you!
Adrian
.X is the older format according to IEC61131-3 Version 2. .%X is the new format according to IEC61131-3 Version 3. Both do the exact same thing. The older standard is supported for compatibilty reasons and for new projects it is recommended to use the new format.
Thank you! Appreciate the quick response!
