Hello I installed the balena-engine using the app store. when loading a container I get following error : x509 certificate has expired or is not valid yet the command : balena-engine run -d -p 1880:1880 -v /opt/plcnext/PPAQ_PROTOBUFF:/usr/src/node-red pxcbe/node-red:protobuff Is there a setting to changes ? I had to switch the PLC to a other IP address due to network access. Br; Piet
skip it. I overlooked the date setting.
