Xenomai kernel extensions
Hi ! Is it possible to include/install Xenomai extensions in the Linux kernel of the PLCnext? Would be compatible with the PLCnext environment? Thanks! Best regards.
Hi Javi, I have consulted with one of our firmware developers, and here is a summary: There seems to be two possibilites for implementing Xenomai extensions:
                                               * A dual kernel approach (_Cobalt_), where a “normal" Linux kernel runs inside a system with a light weight realtime kernel.
                                               * A single Kernel approach (_Mercury_), in which case it is likely that no kernel patch is needed.
The second of these is the “simpler” approach since it appears that only the user-space from xenomai is needed. So this is more likely to work on a PLCnext Control than the first approach … but of course this would need to be proven, and tested thoroughly. Out of interest, since Xenomai appears to be an alternative to the real-time services provided by the PLCnext runtime - what is the reason for considering Xenomai? ~ Martin.
Hi Martin, Thanks for your quick response. I’m not sure what is the reason to consider Xenomai, it’s a question that has been submitted to us by a customer (I suppose that it’s because they are using it or they are familiar with it or…). I’ll try to find out why and keep you posted.
OK, but please make your customer aware that, if they want to try this, they must be experienced with the general process of rebuilding a Linux kernel. In general we cannot do that here, unless there is a compelling reason - in which case please contact us privately. ~ Martin.
