Astronomical clock
I want to create an output based on the time the sun goes down.
Is there an astronomical clock function in the PLC
plcnext codemeter.pdf
Hello hdg,
not directly, but I have written a function block that is able to calculate the sunset and sunrise depending on your geographical coordinates, the time in UTC time and the time difference at your position.
In my function block you can set the mode between civil, nautical and astronomical twilight.
Are you interested?
Best regards
Michael
